Mirka
Mirka Abralon Abrasive Discs 150mm
SKU: 504496
€49,00
  • Silicon carbide abrasive discs with a foam backing
  • Excellent for cleaning, matting, finishing or pre-polishing surfaces
  • 150mm diameter; 600g, 1,000g, 2,000g or, 3,000g
  • Pack of 20
Abralon from Mirka is a fine finishing medium for very fine sanding applications such as cutting back and denibbing paints, varnishes and lacquers prior to polishing. It is also excellent for applying oil finishes to wooden surfaces and cleaning and matting surfaces. The silicon carbide abrasive is resin bonded to a foam backing so is exceptional for use on contoured surfaces and the fabric backing enables attachment to hook and loop sanding pads and blocks. Discs available in 150mm x 600g, 1,000g, 2,000g, 3,000g.
Abrasive Material Silicon Carbide
Abrasive Type Abralon
Abrasive Backing Foam Hook and loop
Diameter 150mm
Pack Quantity 20
Abrasive Grit 600
EAN Barcode 6416868600131
