These hand pads from Mirka are a unique, multi-functional fine finishing medium for very fine sanding applications. They have many uses such as cutting back and denibbing paints, varnishes and lacquers prior to polishing. They are also excellent for applying oil finishes to wooden surfaces and cleaning and matting surfaces. The silicon carbide abrasive is resin bonded to a foam backing so is exceptional for use on contoured surfaces. The fabric
EAN Barcode 5052511087730
