Abranet is a revolutionary abrasive material offering dust free sanding with no clogging. The open mesh design features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These abrasive discs with hook and loop backing are suitable for a wide range of materials including those used in the decorating, woodworking and automotive industries.
Abrasive Type Abranet
Abrasive Backing Mesh Hook and loop
Pack Quantity 10
Abrasive Grit 80
EAN Barcode 6416868670578
