Abranet is a revolutionary abrasive material offering dust free sanding with no clogging. The hook and loop backed open mesh design features thousands of tiny holes which will make sure that when used with suitable extraction the passage of dust will be incredibly efficient. Because Abranet abrasive keeps the surface that you are sanding dust free, this results in a very uniform scratch pattern leaving an ultra-smooth finish. It is incredibly durable and will last twice as long as many conventional abrasives making it very cost effective. These hook and loop backed strips are suitable for a wide range of materials including the decorating, woodworking and automotive industries. Pack of 10.
Abrasive Sheet Size 81 mm x 133 mm
Abrasive Type Abranet
Abrasive Backing Mesh Hook and loop
Pack Quantity 10
Abrasive Grit 80
Web Attribute Set Abrasive Sheets
EAN Barcode 6416868558937
