Extend the versatility of your sander with the Mirka Backing Pad Net 130g Ø125mm. Designed to allow you to use 125mm sanding discs on compatible 150mm sanders, this backing pad offers a simple and effective way to adapt your setup without compromising performance. Ideal for professional and workshop use, it helps you get more from your existing tools while maintaining consistent sanding results.
This 125mm backing pad features a hook & loop (grip) attachment for quick disc changes and has a medium firmness to provide a balanced combination of control and surface conformity. With a 28-hole configuration, it supports efficient dust extraction when used with suitable abrasives, helping to maintain a cleaner working environment and improve finish quality. Designed to fit all Mirka 150mm sanders, it enables easy switching between disc sizes, making it a versatile addition to your sanding system.
Mirka is a globally recognised leader in abrasives and surface finishing solutions, known for its innovative approach and high-performance products. With decades of expertise and a strong focus on efficiency and durability, Mirka continues to develop tools and systems that deliver superior results for professional and enthusiast users alike.
Use with Mirka Abranet and other 125mm sanding discs on compatible 150mm Mirka sanders, creating a flexible and efficient sanding setup tailored to your needs.
