{"product_id":"mirka-deros-ii-5650cv-random-sander-solution-kit-abranet-ace-hose","title":"Mirka DEROS II 5650CV Random Sander Solution Kit, Abranet Ace \u0026 Hose","description":"\u003cp\u003eThis package includes the compact DEROS II 5650CV sander with 200 Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE abrasive discs and anti-static extraction hose.\u003c\/p\u003e\u003cp\u003eThe DEROS II has to be the most compact random orbit sander on the market today. It is supplied with both 125mm and 150mm pads that can be simply swapped over. The body of the machine houses a unique, upgraded 400W brushless motor with motor control technology. With its small body and low weight of just 1kg, it is perfect for all prolonged use in almost any position - flat, overheard or vertical.\u003c\/p\u003e\u003cp\u003eThe control and smoothness is excellent with the motor giving constant speed even under load; it is fitted with soft start and electronic brake. The sanding speed is adjustable, with the range covering 4,000 - 10,000 rpm. The updated design makes it easy for the operator to change; LED indicators are located on the speed selector, together with a separate on\/off switch and lockable speed for optimum control. The DEROS II also features a closed construction so that no dust can enter the machine, causing wear. The power cord is exchangeable.\u003c\/p\u003e\u003cp\u003eThe 125mm and 150mm backing pads can be exchanged quickly to suit your application; both pads have a universal hole pattern to enable the fitting of many different makes and types of abrasive disc.\u003c\/p\u003e\u003cp\u003eMirka Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE abrasive has been developed for those tougher and more demanding sanding applications. Due to its optimised net construction and ceramic grit, it gives a superior cutting performance on hard wood (for example, beech and oak) as well as fast cutting on various solid surface materials.\u003c\/p\u003e\u003cp\u003eAbranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE is also excellent for all paint sanding applications, with optimal performance and an enhanced disc life.\u003c\/p\u003e\u003cp\u003eThe anti-static extraction hose has a 27mm outlet, is 4m in length and is supplied with adaptor. The swivel exhaust outlet on the machine is also antistatic. One of the key features of the Mirka DEROS II is the enhanced Bluetooth low energy technology, which helps you reduce your exposure to vibration.\u003c\/p\u003e\u003cp\u003eThe DEROS II package includes DEROS II sander in a T-LOC case, 200 Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE discs and extraction hose.\u003c\/p\u003e\u003cp\u003eThe DEROS II is supplied with:\u003c\/p\u003e\u003cp\u003eA stacking storage case with 125mm and 150mm backing pads\u003c\/p\u003e\u003cp\u003e50 x Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE grit P80 abrasive discs\u003c\/p\u003e\u003cp\u003e50 x Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE grit P120 abrasive discs\u003c\/p\u003e\u003cp\u003e50 x Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE grit P180 abrasive discs\u003c\/p\u003e\u003cp\u003e50 x Abranet\u003cspecial id=\"9\"\u003e\u003c\/special\u003e ACE grit P240 abrasive discs\u003c\/p\u003e\u003cp\u003eAnti-static 4m extraction hose\u003c\/p\u003e\u003cp\u003e2+1 Extended Warranty on Mirka sanders, registration required within 30 days.\u003c\/p\u003e","brand":"Mirka","offers":[{"title":"Default Title","offer_id":54118509707611,"sku":"111717","price":715.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111717_xl.jpg?v=1789783823","url":"https:\/\/www.axminstertools.com\/products\/mirka-deros-ii-5650cv-random-sander-solution-kit-abranet-ace-hose","provider":"Axminster Tools","version":"1.0","type":"link"}
