The Mirka DEROS RS 600 sander is fitted with a 150mm diameter sanding pad and is supplied as a Kit with additional 75 x sanding abrasives. Powerful and versatile with low profile and weight designed for heavy-duty, coarse sanding applications. This kit is ideal for many sanding tasks; sand wood, paint strip, floors and decks. micro-cement work, car body work and more.
Fitted with a Mirka brushless motor the RS600 rotary sander is robust in design and a powerful whilst maintaining a smooth and silent operation, delivering aggressive sanding action, ideal for coarse sanding and fast work progress on various surfaces including wood and metal. Low profile and easy to manoeuvre with a very low vibration it is very comfortable to use. The combination of power, lightweight design, and low noise levels make it suitable for both professional and DIY projects.
Operating with a slow start and then at a constant speed when the user presses start/stop button, the lock mode allows the tool to keep running without the need to hold the start button continuously. Increase or decrease speed to the desired level (700-2500rpm) with an LED bar displaying the current speed setting. Ramp up mode gradually increases speed to a selected setting as the user applies load and decreases speed as the user reduces load. DEROS RS 600 is compatible with the myMirka app over Bluetooth® for monitoring vibration levels and other connectivity features.
The kit includes the Mirka DEROS RS 600 sander, along with ABRANET ACE HD 150mm Grip sanding discs in P40, P60, and P80 grits. The included shroud guides dust in the right direction when sanding with a pad saver, ensuring a cleaner work environment.
Contents: DEROS RS in Systainer case with 3 boxes Abranet ACE HD 150mm sanding pad and 75 x 150mm abrasive discs in packs 25 each -P40, P60, P80
Corded or Cordless Corded
Motor Power (230 V)
Web Attribute Set Random Orbit Sanders
EAN Barcode 6416868338911
