Silicon carbide grain coated onto two sides of low-density foam to enable a premium finish on profiled or flat surfaces. Used wet or dry, they are excellent for preparation of surfaces prior to re-coating. Choose from a mixed pack comprising 10x 180 and 10x 220 grit or a pack of 20x 220 grit. Each sanding sponge measures approx 98 x 120 x 13mm.
Mirka
Mirka Double-Sided Sanding Sponge (Pkt 20)
| Abrasive Material | Silicon Carbide |
| Abrasive Backing | Foam |
| Abrasive Grit | 220 |
| Web Attribute Set | Sanding Pads & Sponges |
| EAN Barcode | 5052511080236 |
