Mirka
Mirka Dust Free Sanding Kit + 250 Abranet Sheets
SKU: 101148
€125,00
  • Makes dust free hand sanding a reality
  • 250 sheets of Abranet (50 each: 120, 180, 240, 320 and 400g)
  • Includes 4m x 20mm hose for connection to vacuum extractor
  • 70 x 125mm with hook and loop base
  • Abranet abrasive guarantees dust free sanding without clogging
This kit makes dust free sanding a reality, containing everything you need except a vacuum extractor. It comprises a Mirka hand sanding block, 70 x 125mm, hose and a variety of Abranet abrasive sheets to suit. The hand sanding block has a hook and loop base to secure the abrasive. It is light in weight and very comfortable to hold. The 20mm x 4m hose fits directly onto the Mirka hand sanding block. At the opposite end a universal cone shaped fitting enables connection to many vacuum type extractors. The Abranet abrasive guarantees dust free sanding without clogging. This open mesh features thousands of tiny holes which ensure the passage of dust will be incredibly efficient. Using the vacuum system keeps the surface that you are sanding dust free resulting in an ultra smooth finish. In addition to the sanding block and hose, the kit contains 250 sheets of Abranet (50 of each: 120g, 180g, 240g, 320g and 400g).
Abrasive Type Abranet
Abrasive Backing Mesh Hook and loop
Web Attribute Set Hand Sanding Blocks
EAN Barcode 6416868302677
