Achieve precise, consistent edge sanding with the Mirka Edge Guide for DEROS 125 / 150mm Random Orbit Sanders. Designed to attach directly to your sander, this clever accessory allows you to guide the tool along edges with control and confidence. With an adjustable angle from 45° to 90°, it’s ideal for everything from standard edge work to bevels and chamfers, helping you produce accurate, repeatable results every time.
This edge guide is compatible with Mirka DEROS 125mm and 150mm sanders and attaches quickly without the need for additional tools. It keeps the sander steady at the desired angle, reducing the risk of tipping and improving overall control during use. Designed with user comfort in mind, it offers an ergonomic sanding experience while ensuring high precision across a range of edge applications. The integrated felt pad helps prevent marks and scratches where the guide meets the surface, delivering a clean, professional finish.
Mirka is a globally recognised leader in abrasives and surface finishing solutions, known for its innovative approach and high-performance products. With decades of expertise and a strong focus on efficiency and durability, Mirka continues to develop tools and systems that deliver superior results for professional and enthusiast users alike.
Use with Mirka DEROS sanders (125mm and 150mm) alongside your preferred Mirka abrasives, such as Abranet or Gold, to create a precise, efficient edge sanding system.
EAN Barcode 6416868358667
