This 33-hole interface pad is suitable for the Mirka DEROS sander. 10mm thick, the pad fits between the baseplate of the sanding machine and the sanding disc. This is invaluable when sanding rounded surfaces and contours. The interface pad stabilises the sanding process and will also help produce a softer result.
EAN Barcode 6416868913040
