The thick foam cushion of these Mirka hook and loop backed interface pads will allow better sanding of contoured surfaces and will also help to extend the life of the backing pad on your random orbit sander. The multi-hole configuration allows fitting to many different makes of sander. They are fitted between the sanding pad and the abrasive disc minimising wear of the sanding pad, simply peel off and discard when it eventually becomes worn. Whe
Mirka
Mirka Interface Pad 125mm (Pkt 5)
| EAN Barcode | 5052511087709 |
