Mirka
Mirka Mirlon Finishing Pads 115 x 230mm (Pkt 3)
SKU: 502612
£3.18
£2.65 Excl. VAT
  • Excellent for many sanding and polishing tasks
  • Available in packs of three 360g 0r 1500g
  • Non-clogging, can be used wet or dry
  • Pad size 230 x 115mm
A range of flexible, three dimensional abrasives suitable for almost any surface, be it woods, metals, paint, GRP or lacquer. It has many advantages over conventional abrasives in that the open web design is non-clogging, can be used wet or dry. It is ideally suited to flat or contoured surfaces. Perfect for keying surfaces and creates an excellent base for the next lacquer layer. Available in packs of three in 360g or 1500g.
Abrasive Material Aluminium Oxide Silicon Carbide
Abrasive Type Mirlon
Abrasive Backing non-woven
Abrasive Grit 360
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 6416868253436
