Mirka pad saver discs are an excellent idea to extend the life of the backing pad on your random orbit sander. The multi-hole configuration on the 150mm version allows fitting to many different makes of sander. They are fitted between the sanding pad and the abrasive disc minimising wear of the sanding pad, simply peel off and discard when it eventually becomes worn. When using Abranet® abrasive discs with many random orbit sande
Mirka
Mirka Pad Saver 125mm 44 hole (Pkt 5)
| EAN Barcode | 5052511087686 |
