{"product_id":"mirka-pad-savers-81-x-133mm-pkt-5","title":"Mirka Pad Savers 81 x 133mm (Pkt 5)","description":"\u003cp\u003eMirka pad saver discs greatly extend the working life of the backing pad on your DEOS 353CV orbital sander.\u003c\/p\u003e\u003cp\u003eThe pad saver sits between the sander and the abrasive, minimising the wear and degradation of your sander's backing pad, caused by heat build-up when sanding for extended periods. In addition the backing pad adds a slight cushioning effect for better performance when contour sanding. When the pad saver eventually wears, simply peel off, discard and replace with a fresh pad saver. These pad savers are a wise investment especially if your sander is in everyday use.\u003c\/p\u003e","brand":"Mirka","offers":[{"title":"Default Title","offer_id":54118328828251,"sku":"105565","price":31.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105565_xl.jpg?v=1789775866","url":"https:\/\/www.axminstertools.com\/products\/mirka-pad-savers-81-x-133mm-pkt-5","provider":"Axminster Tools","version":"1.0","type":"link"}
