The Mirka ROS650DB is a 150mm air powered random orbital sander with a 5.0mm orbit. It is fitted with a central vacuum port and dust bag system which ensure completely dust free sanding without requiring connection to an extraction system. This sander is extremely light in weight, very well balanced and can be used for long periods. The speed can be regulated through a range of 4-12,000rpm. Suitable for use on all kinds of surfaces and capable of a very fine finish. A great sander for work surfaces, large furniture and vehicle use. 2+1 Extended warranty on Mirka sanders, registration required within 30 days. The tool is supplied with a 1/4
Mirka
Mirka ROS650DB 150mm Random Orbit Sander
| Inlet | 1/4 BSP |
| No Load Speed | 12,000 rpm |
| Sound Power Level LwA [Uncertainty K] | [1.5 dB] 83 dB(A) |
| Vibration Sanding [Uncertainty K] | 3.5 m/s² |
| Web Attribute Set | Air Sanders |
| EAN Barcode | 6416868928839 |
