Masking tape is one of those items that will usually cause immense irritation when a poor quality product is used. It will refuse to stick and if it does will generally peel off at the slightest provocation. Not so with Model Craft Precision Masking Tape. This is a thin, but very strong paper tape which will stick to almost any surface allowing a precise and intricate masking facility for smaller modelling applications. It is UV protected for masking projects in direct sunlight and, because it is so thin, there is very little chance of paint 'bleed' or annoying paint lines. Each roll is 18m long and is available in different widths.
Model Craft
Modelling Masking Tape
| Web Attribute Set | Masking Tape |
| EAN Barcode | 5060252024600 |
