This is a set of three double-ended box spanners complete with a tommy bar. A great problem solver, that saves a lot of time and frustration when it comes to gaining access to tap back nuts.
The set comprises the following sizes: 8 x 10mm, 9 x 11mm and 12 x 13mm. Each is approximately 150mm long, to fit over an extended threaded stud. The Monument 3240U box spanner set is just the job when working in those awkward under sink areas.
Manufacturer Part Number 3240U
Web Attribute Set Plumbing Tools
EAN Barcode 5015375032407
