Capture the thrill of the open road with this beautifully crafted Motorcycle Pen Kit. From the straight pipes to the muscular lines of the old school motorcycle engine with kickstart mechanism, your custom-built pen will make a statement.
The pen tip features a fierce, intricately cast eagle head. A true to life old school single cylinder engine adorns the pen end. A machined shock absorber "kickstart" mechanism, that replicates a kickstarter pedal, sits beneath the engine while a straight exhaust pipe acts as the pen clip. This mechanism functions the same way as our Bolt Action pen kits to smoothly advance and retract the refill. Easy to make with a single 10mm tube and includes a smooth writing Parker™ style refill.
Uses 106278 bush set and a 10mm (502172) drill bit. Blank size 16mm x 16mm x 150mm.
Pen Kit Classification Master
Difficulty Confident
Drill Bit Required 10 mm
Bushing Set Order No. 106278
Minimum Blank Size 19 mm x 19 mm x 60 mm
Pen Type Action Pen
Colour Chrome Web Attribute Set: Project Kits
EAN Barcode 5052511118069
