The Narex 0.75mm Marking Knife is a precision woodworking tool for creating clean, accurate layout lines for joinery, cutting and chiselling. The fine blade offers precision and slight flexibility, which is particularly useful when accuracy and clearly defined reference lines are essential.
The exceptionally thin 0.75mm blade is designed to follow the edge of a square or straightedge closely, helping produce precise layout marks across and along the grain. The marking knife's cut-out handle provides a distinctive design and controlled grip, while the narrow blade is well suited to detailed woodworking and fine joinery. The blade is made of heat-treated steel with a hardness of 60 HRc and the handle is exotic rosewood. It's a practical addition to any workshop where accurate marking is an important part of the process.
Narex is a well-established name in woodworking tools, combining traditional toolmaking expertise with practical designs for modern workshops. Its tools are made for woodworkers who value precision, dependable performance and quality materials.
