The Narex 200mm Fine Rasp Set is a versatile 3-piece wood rasp set designed for controlled shaping, refining and smoothing timber. The fine-cut teeth remove material efficiently while leaving a cleaner finish than a coarse rasp, making the set ideal for furniture making, woodcarving, joinery and general woodworking, as well as model making and crafts which require high control over material removal. With three different rasp profiles included (flat, round, half-round), it's easy to tackle flat surfaces, curves and detailed shaping with confidence.
This set includes three 200mm long fine-cut wood rasps, each of which is manufactured from durable heat-treated steel with a hardness of 45 HRc for long-lasting performance. They also feature an ergonomic hornbeam handle for a comfortable, secure grip during extended use, finished with a stain and wax for durability. The variety of profiles provides excellent versatility for shaping edges, contours, joints and decorative details in both hardwood and softwood, without tearing the grain or requiring further fine finishing.
Narex is renowned for producing reliable woodworking tools that combine quality materials with precision manufacturing. Trusted by professional makers and keen hobbyists alike, Narex tools are designed to deliver dependable performance, accuracy and long-term value in the workshop.
Web Attribute Set Hand Rasps
EAN Barcode 8590137542525
