Built for demanding workshop and site use, the Narex HEAVY DUTY Flat Chisel Set combines a full through-blade construction with hardened steel striking ends, delivering outstanding strength and reliability under repeated heavy blows. Each chisel features a transparent handle that not only sets it apart visually but also provides reassurance of its robust internal construction, while the ergonomic, anti-roll design ensures comfort, control and stability during prolonged use.
A professional-grade set of flat carpentry chisels engineered for both precise paring and intensive material removal. Covering a practical range of sizes, it’s capable of handling everything from fine bench work to heavy-duty chopping, making it a dependable, go-to kit for any serious woodworker.
Narex has built a strong reputation for producing high-quality hand tools that combine traditional craftsmanship with modern engineering. Known for durability, precision and excellent value, Narex tools are trusted by professional tradespeople and dedicated woodworkers across the globe.
Combining strength, control and durability, each chisel in the set features a full through-blade construction, hardened striking end and ergonomic transparent handle with anti-roll profile; supplied as a four-piece set.
6mm – overall length 298mm
12mm – overall length 304mm
20mm – overall length 312mm
26mm – overall length 318mm
This four-piece set includes 6mm, 12mm, 20mm and 26mm chisels, offering excellent versatility and better value compared to purchasing individually. Ideal for use with a wooden mallet or hammer, and pairs well with sharpening systems to maintain a keen, durable edge.
All four sizes available to purchase individually.
Web Attribute Set Chisel Sets
EAN Barcode 8590137607019
