8 piece set containing 6mm, 10mm, 12mm, 14mm, 18mm, 20mm, 22mm and 26mm widths.
This set contains eight Bevel Edge chisels, well chosen to include the most commonly used sizes, and represent great value for money.
The blades are forged from Narex’s own Chrome Manganese (Cr-Mn) steel. This is a low-alloy high-carbon steel developed specifically for edge tools. The steel has a very fine structure and is hardened and tempered to 59 HRC. The blades are fully ground and will take and hold a good edge. The polypropylene handle is comfortable with an oval cross section, so as to not roll off your bench. A hanging hole is provided.
Quality tools made in Europe. These chisels meet DIN 5139 requirements.
Web Attribute Set Bevel Edge Chisels
EAN Barcode 5052511132287
