Narex rotary rasps feature hand-cut teeth. This sets them apart from similar cheaper machine made examples. Hand-cut or hand-stitched teeth offer a far superior performance. These rasps cut faster and leave a smoother finished surface.
Hand stitching involves a highly skilled employee cutting each tooth individually using a hammer and small chisel. The result is a medium/coarse (60 teeth per cm) cutting tool with a very slightly irregular tooth pattern. It is this pattern that actually helps to minimise deep scoring and tearing of the wood fibres, leaving a superior surface finish.
Available in different profiles to cover a wide variety of rotary carving and shaping tasks.
Suitable for use in mains or cordless drills, shank size 6mm, max speed 3,000rpm. Overall length approximately 60mm
Quality tools made in Europe.
Rasp Type Type 2 Short Cone 25 x 13mm
Web Attribute Set Power Carving Accessories
EAN Barcode 8590137725911
