The handles have a rounded hexagonal cross-section and are ergonomically shaped to allow you to apply the necessary torque without discomfort. The top end of the handles have convenient hanging holes. The blades are heat treated highly alloyed steel. They are chrome plated against corrosion with blacked tips for wear resistance.
The 5 piece set contains:
Slotted
3.0 mm x 75 mm
4.0 mm x 100 mm
6.5 mm x 150 mm
Phillips
PH1 x 80 mm
PH2 x 100 mm
Quality tools made in Europe.
Web Attribute Set Screwdriver Sets
EAN Barcode 8590137640009
