Built for demanding workshop and site use, the Narex HEAVY DUTY Flat Chisel combines a full through-blade construction with a hardened steel striking end, delivering outstanding strength and reliability under repeated heavy blows. The transparent handle not only sets it apart visually but also provides reassurance of its robust internal construction, while the ergonomic, anti-roll design ensures comfort, control and stability during prolonged use.
A professional-grade flat carpentry chisel engineered for both precise paring and intensive material removal. Capable of handling everything from fine bench work to heavy-duty chopping, it’s a dependable addition to any serious toolkit.
Narex has built a strong reputation for producing high-quality hand tools that combine traditional craftsmanship with modern engineering. Known for durability, precision and excellent value, Narex tools are trusted by professional tradespeople and dedicated woodworkers across the globe.
Combining strength, control and durability, this chisel features a full through-blade construction, hardened striking end and ergonomic transparent handle with anti-roll profile; supplied as a single chisel, pieces per pack: 1, carton quantity: 10.
6mm – overall length 298mm
12mm – overall length 304mm
20mm – overall length 312mm
26mm – overall length 318mm
Available individually in 6mm, 12mm, 20mm and 26mm. Ideal for use with a wooden mallet or hammer, and pairs well with sharpening systems to maintain a keen, durable edge.
Four-piece set available (SKU 114158).
