Meet the ProVac, the famous Henry's tough cousin. Full of innovation, this ECO A rated machine is ready to swallow any demanding task. It has a plugged rewind cable system with 12m of cable stored under a large, folding carry handle. This cable is designed for easy replacement if it becomes damaged, just a simple screwdriver job. The front castors are protected from impact damage, whilst two large rear wheels move easily over rough surfaces. The Tritex filter and easy change HepaFlo bags give you brilliant filtration and safe waste disposal. All the usual Henry ease of use, convenience and hard working nature are still here, but this machine is better suited to a tough site or workshop jobs. However, if you want one for the house, then that's perfectly OK. Best of all, this machine is exactly the same price, so it's easy on the wallet as well. Just like a Henry, it will go on and on and on.
Supplied with Numatic AS1 32mm Stainless Steel Accessory Kit, which includes a 2.2m FloMax hose, Stainless Steel tubes, floor cleaning head for hard and soft floors, a variety of brushes and nozzles.
Overall L x W x H 355 mm x 350 mm x 415 mm
Rating Trade/Professional
Corded or Cordless Corded
Max Capacity Dry 9 litre
Airflow Volume 2,880 litre/min
Sound Pressure Level LpA [Uncertainty K] 64 dB(A) [0.5 dB]
Motor Power 620 W
Plug Fitted UK 3 pin plug
Made in Britain Yes
Model PPR240-11
Extractor Classification
Nett Weight 9.1 kg
Suction 22.6 kPa
Voltage 230 V
Warranty Numatic 2 Year Warranty
Made in Britain Yes
EAN Barcode 5028965615218
