The Numatic TRM240 M Class Vacuum Cleaner 230v is a high-performance vacuum designed to protect workers from harmful dust particles by capturing even the smallest particles, ensuring clean and safe air. This vacuum is ideal for light to medium hazard applications and is essential for construction and building sites, as it meets the legal requirements for vacuuming 'medium risk' hazardous dusts under COSHH (Control of Substances Hazardous to Health) regulations. You'd buy this product for its efficiency, durability, and compliance with safety standards, making it a valuable tool for maintaining a safe work environment.
The TRM240 features a 9-litre capacity and is made from high-quality materials, including a 620W motor that offers high efficiency and low energy consumption. It includes a low-flow indicator that alerts you when airflow drops due to blockage or a full bag, ensuring optimal performance. The vacuum also has a secure blanking cap to retain dust within the machine when the hose is disconnected. Its lightweight and easy-to-use design, along with simple rewind cable storage, make it a practical choice for any worksite. Additionally, the HEPA14 filtration system is ten times better than HEPA13, providing superior dust capture and protection. The filter is washable.
Supplied with: Professional and versatile AS76 accessory kit. This includes Stainless Steel Extension Tube (x2), Stainless Steel Tube Bend with NPC Volume Control, 300mm MultiFlo Dry Brush Tool, 2.8m NuFlex Threaded Hose, 38mm/23mm Adaptor, 65mm Soft Dusting Brush, Double Taper Hose / Tool Adaptor and 240mm Crevice Tool.
Overall L x W x H 360 x 360 x 390mm
Corded or Cordless Corded
Cable Length 10 m
Max Capacity Dry 9 litre
Airflow Volume 2,880 litre/min
Sound Pressure Level LpA [Uncertainty K] 70 dB(A) [2.0 dB]
Motor Power 620 W
Plug Fitted UK 3 pin plug
Made in Britain Yes
Web Attribute Set Vacuum Cleaners - Dry
EAN Barcode 5028965868355
