Numatic
Numatic WV 380-2 Wet & Dry Vacuum Cleaner
SKU: 990003
£276.98
£230.82 Excl. VAT
  • Industrial wet or dry vacuum
  • 1,200W bypass motor
  • Supplied with float valve for automatic shut off when full of liquid
  • Excellent dry performance
  • Heavy duty Structofoam body
  • 15 litres dry / 9 litres wet capacity
  • Four castors on base for mobility and stability
  • Full wet and dry tool kit included
The WV-380s are, by design, wet or dry vacuum cleaners that perform totally without compromise in either mode. When you want to operate as a dry machine performance must be as good as a dry-only machine, with big filters and the option of giant HepaFlo disposable dust bags ensuring a high standard of operation. Similarly, when required for wet work, a quick switch of the dry filter for the wet float valve and a change of floor nozzle will give you equally professional performance and a clean, dry floor at the end of it all. Extremely ruggedly built, with Numatic's patented Structofoam container and amply powered by a 1,200W "Twinflo" motor.
Supplied with Numatic AA12 Aluminium MultiFlo 32mm Accessory Kit which includes 2.4m Nuflex hose, aluminium extension tubes, dry nozzle and wet pick up nozzle.
Overall L x W x H 355 mm x 355 mm x 510 mm
Rating Trade/Professional
Corded or Cordless Corded
Cable Length 10 m
Max Capacity Dry 15 litre
Airflow Volume 2,700 litre/min
Sound Pressure Level LpA [Uncertainty K] 77 dB(A) [0.2 dB]
Motor Power 1,200 W
Made in Britain Yes
Web Attribute Set Vacuum Cleaners - Wet & Dry
EAN Barcode 5028965246078
