Osmo Top Oil is a strong, durable oil designed to enhance the natural beauty of wood on tables and kitchen worktops drying to a clear, matt finish. Based on natural waxes and oils, Osmo Top Oil does not peel, flake, crack or blister which allows for good performance in high humidity areas. It is a hard-wearing oil with excellent resistance to water, juices, wine, beer and fizzy drinks. It is quick and easy to apply with a cloth, roller or paint brush by applying two or three thin coats. No primer is required. The grain of the wood is enhanced once Osmo Top Oil has been applied and if the final finish is not shiny enough, buffing it with a cloth will create a sheen. As the natural oils and waxes penetrate deep into the surface they help to keep the wood supple, preventing it from getting dry and brittle thus reducing any movement.
Coverage 24 m per litre
Application Method Brush Roller
Drying Time 8 to 10 hours
Clean Up White Spirit
Web Attribute Set Oil Finishes
EAN Barcode 4006850118823
