Package deal comprises two Axcaliber FineLine PTFE Coated Handsaws: 11tpi - 500mm (20") and 7tpi - 550mm (22").
With their razor sharp, triple diamond ground teeth these saws cut with an amazing speed. The blades are 1mm thick steel and have a low friction PTFE coating that also protects against corrosion. The teeth are electronically hardened and diamond ground. Each saw has a heavy duty, 2-part comfort handle that incorporates 45° and 90° angles. The shorter 500mm long saw features 11tpi, offering a fine finish when crosscutting. The longer 550mm saw performs particularly well on thicker timber with its 7tpi producing a fast smooth cutting action.
