The Pégas® guiding system is required when using Pégas scroll bandsaw blades. The blade will be guided accurately for high- performance, sustainable sawing results.
The top and bottom guides consist of a CNC-machined aluminium block and a special ball-bearing guide, featuring grooves along which the blade is guided above and beneath the table. Such high-precision guiding allows for the sawing of very complex shapes, curves and radiuses.
The ball-bearings (92.000-U) delivered with the Pégas Scroll Bandsaw feature two grooves of different dimensions, one being appropriate for blade #9 and the other for blade #12.
Other ball-bearings are offered optionally for optimal guiding of the various Pégas scroll bandsaw blades. Please refer to the downloadable chart to select the correct bearing for your blades.
