This fast cutting blade leaves a smooth finish and is particularly effective in soft woods.
Pegas double reverse skip saw blades have the same basic tooth geometry as double skip blades except that they have a number of reverse teeth at the bottom of the blade. Reverse teeth prevent splinters from developing on the underside of the workpiece. This tooth arrangement results in efficient chip removal and helps prevent the wood from burning.
Thickness 0.46mm, width 1.14mm, overall length 130mm with plain ends, tpi 10.5/7.
Additional Accessories No
Scroll Saw Blade Length 130 mm
Web Attribute Set Scroll Saw Blades
EAN Barcode 5052511114177
