Progressive tooth blades are versatile, performing well in wood, plastic, bone, Corian® and most fibrous materials. These blades feature fine entry teeth to avoid splitting or tear-out and have coarser teeth in the centre to clear the waste. Perfect for coated materials or veneered surfaces, they give a very clean internal cut. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
Scroll Saw Blade Length 130 mm
Grade Fine
Web Attribute Set Scroll Saw Blades
EAN Barcode 5052511096374
