These blades have the same basic tooth geometry as skip blades except that a limited number of reverse teeth have been added to the bottom of the blade. Reverse teeth prevent splinters from developing on the underside of the workpiece because the top teeth do not cut entirely through the work. All operating parameters are the same as other blades. Overall blade length 130mm.
For more information on each blade please see 'Information Downloads' below.
Scroll Saw Blade Length 130 mm
Size 3R
Size & tpi 3R - 13/7r tpi
Size & Ref Number (3R) - 90.428
Banding Thickness 0.33mm Web Attribute Set: Scroll Saw Blades
EAN Barcode 5052511096039
