Pegas
Pegas Skip Tooth Scroll Saw Blades
SKU: 101731
£4.78
£3.98 Excl. VAT
  • Heat treated high carbon steel
  • Versatile, suitable for many materials
  • Made in Switzerland
  • Blade length 130mm
  • Packs of 12
Skip tooth blades are versatile, performing well in wood, plastic, bone, Corian and most fibrous materials. These blades provide excellent chip removal, accept a fast feed rate and give a smooth finish. The range of sizes and teeth per inch allows the cutting of intricate patterns as well as rough-cut work. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
For more information on each blade please see 'Information Downloads' below.
Scroll Saw Blade Length 130 mm
Size 4
Size & tpi 4 - 38 tpi
Size & Ref Number (4) - 90.546
Web Attribute Set Scroll Saw Blades
EAN Barcode 5052511096244
