The Pegas Wood Scroll Saw Blade Starter Pack consists of 18 x 130mm plain ended blades: 3 each of No.1, 3, 5 and 7 skip blades, and 3 each of No.3 and 5 variable geometry blades. This pack is designed to give the beginner scroll saw user an idea of what each common blade does and allows the user to determine which blade is best suited to their scroll sawing work. This pack is also supplied with each new Professional scroll saw sold by Axminster. Made in Switzerland from high speed steel.
Scroll Saw Blade Length 130 mm
Web Attribute Set Scroll Saw Blades
EAN Barcode 5052511095834
