These Pen Turning Kits comprise 4 of our most popular twist pen kits, along with 4 different pen blanks, plus an Axminster Pen Mandrel, Barrel Trimmer and 7mm HSS Pen Drill. To begin turning these classy looking writing implements all you need to add is a lathe and a few sharp turning tools.
The blanks include 2 acrylic, plus an oak and a walnut blank. The kits are excellent quality, straightforward to turn and construct. Each pen kit includes a tungsten carbide tipped refill to provide smooth, trouble-free writing. The bushes supplied with the Axminster Pen mandrel are the correct diameter for these kits.
By the time you have finished the kits, you will have become an experienced pen turner.
These make perfect gifts, giving someone else the pleasure of owning a unique pen with which to write a thank-you note.
Choose 1MT or 2MT to suit your lathe.
Contents:
Artisan 10 Karat Gold Twist Pen Kit
Artisan Chrome (A Logo) Twist Pen Kit
Artisan Chrome (Black Clip) Twist Pen Kit
Artisan 24 Karat Gold Twist Pen Kit
White Lightning Acrylic Pen Blank
Classic Acrylic Pen Blank
Walnut Pen Blank
Oak Pen Blank
Barrel Trimmer
HSS Pen Drill 7mm
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm x 16 mm x 112 mm
Morse Taper 2 MT
Pen Type Twist Pen
Refill Order Number 310492
Intended Use Starter set to make 4 different Twist pen kits.
Colour Mixed Web Attribute Set: Project Kits
EAN Barcode 5052511120383
