Perfect beginner woodturning tools, this Perform HSS Woodturning Chisel Set comprises of 4 of the most essential turning tools; an ideal accompaniment to the Perform PD205WL Woodturning Lathe. The blades are HSS, mounted to 200mm smooth beech handles. They feature stainless steel captive ferrules.
The set includes:
19mm roughing gouge - for removing the corners of square stock and initial rough shaping.
19mm skew chisel - this chisel has rounded edges to helping when cutting beads. It's used for planing cuts, trimming end grain and making your piece round.
10mm spindle gouge - for cutting coves, concave shapes and adding detail.
3mm parting tool - for parting work from the waste and cutting deep grooves when sizing.
Blade length: roughing gouge 130mm, skew chisel 140mm, spindle gouge 150mm and parting tool, 120mm.
Web Attribute Set Woodturning Tools - Sets
EAN Barcode 5052511143092
