The Perform PD1400B Bandsaw is ideal for beginners or small home workshops.
It features a strong chassis with a cast aluminium table, providing a solid, sturdy working area. The machine accommodates blades between 4.8 mm and 9.5 mm wide and offers a maximum cutting height of 80 mm, delivering excellent versatility for a variety of cutting tasks.
Driven by a reliable, quiet induction 250W motor, the PD1400B delivers a blade speed of 960 m/min. It has balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close. The quick tension release ensures for simple and rapid blade changes.
Bearing blade guides and a thrust bearing provide maximum blade control, ensuring improved accuracy and clean cuts.
The 300 x 300 mm table tilts to 45 , whilst the rack and pinion allows for smooth table adjustment so you can cut at different angles with ease. A mitre fence is included, allowing you to produce accurate crosscuts whilst the rip fence ensure for straight and accurate cuts.
The micro-switched doors ensure the machine automatically stops running if a door is accidentally opened, providing an extra layer of safety during use.
The 28mm dust extraction outlet allows efficient dust collection when connected to a suitable vacuum extractor, helping to maintain a clean and safe workspace.
This compact, yet versatile machine makes an excellent beginner bandsaw. It's great for cutting wood, aluminium and plastic.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 63 mm
Max Width of Cut with Fence 130 mm
Overall L x W x H 420 x 400 x 690 mm
Power 250 W
Rating Occasional Use
T Slot Size 10.5 x 3.5 mm
Table Height 320 mm
Table Size 300 x 300 mm
Table Tilt 0 - 45
Min Extraction Airflow Required 200 m³/hr
Plug Fitted UK 3 pin plug
Web Attribute Set Bandsaws
EAN Barcode 5052511142194
Accessories
  • UJK Bandsaw Buddy UJK Bandsaw Buddy
    £16.49 £19.98 Save £3.49
  • Axminster Push Stick
    Spare Parts
    • Axcaliber Pack of 3 Blades for PD1400B Bandsaw
      Out of Stock Special Offer
      £26.71 £33.38 Save £6.67
    • Axcaliber High Carbon Bandsaw Blades Axcaliber High Carbon Bandsaw Blades
