{"product_id":"perform-pd150bds-belt-disc-sander-230v","title":"Perform PD150BDS Belt \u0026 Disc Sander 230V","description":"\u003cp\u003eThe Perform PD150BDS Belt \u0026amp; Disc Sander is a compact and neatly designed, light use sander. It features a 100mm x 915mm belt and a 150mm disc. The belt sanding platen can be used vertically or horizontally. The worktable can be used for either function, and tilts up to 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. The mitre fence allows easy bevel and compound angle sanding.\u003c\/p\u003e\u003cp\u003eThe machine has close fitting guarding and a 63mm dust extraction outlet. When connected to a suitable vacuum extractor, it offers almost total dust extraction. The main body of the machine is a single cast iron therefore is strong and stable. It has locating holes for securing the sander to a workbench.\u003c\/p\u003e\u003cp\u003eThe PD150BDS makes an ideal beginner sander or for those simply using it for light use for shaping, sanding and profiling. There is a selection of hook and loop abrasive belts and discs available for various applications.\u003c\/p\u003e\u003cp\u003ePlease note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePlease note, if you require an EU plug, please ensure you purchase 113504\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Perform","offers":[{"title":"Default Title","offer_id":54118671253851,"sku":"113366","price":140.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113366_xl.jpg?v=1789791017","url":"https:\/\/www.axminstertools.com\/products\/perform-pd150bds-belt-disc-sander-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
