The Perform PD150BDS Belt & Disc Sander is a compact and neatly designed, light use sander. It features a 100mm x 915mm belt and a 150mm disc. The belt sanding platen can be used vertically or horizontally. The worktable can be used for either function, and tilts up to 45
The machine has close fitting guarding and a 63mm dust extraction outlet. When connected to a suitable vacuum extractor, it offers almost total dust extraction. The main body of the machine is a single cast iron therefore is strong and stable. It has locating holes for securing the sander to a workbench.
The PD150BDS makes an ideal beginner sander or for those simply using it for light use for shaping, sanding and profiling. There is a selection of hook and loop abrasive belts and discs available for various applications.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
