The Perform PD216SMS Slide Mitre Saw is a compact tool designed with cutting versatility and space saving in mind. Featuring a forward facing guide rail system, this saw can be positioned closer to the wall - ideal for workshops with limited floor space.
Equipped with a 1.4kW motor and a 216mm diameter blade, the PD216SMS delivers a blade speed of up to 5,000rpm, enabling smooth and precise cuts across a variety of materials. The Teflon-coated blade offers contract-grade performance straight out of the box.
This mitre saw supports a wide range of cutting angles, mitring from 0
To help keep your workspace clean, a dust bag is provided or there's a 38mm dust extraction outlet that you can connect to a vacuum extractor.
Ideal for tasks such as decking, trim, moulding, and other indoor or outdoor woodworking projects, this saw is perfect for beginners or as a reliable, light-duty addition to any workshop.
