Perform
Perform PD405FS Scroll Saw 230V
SKU: 113361
€125,00 €135,00 Save €10,00
  • 406mm throat allows for larger projects
  • Includes Flexible Shaft and accessory kit
  • Variable speed for cutting various materials up to 50mm
  • Perfect machine for creative and detailed work
More than just a scroll saw, the PD405FS is a versatile hobby station designed for creative and detailed work. It includes a flexible shaft with an accessory kit, making it suitable for a wide range of hobbyist applications.
Powered by a robust DC motor, the PD405FS features variable speed control to accommodate a variety of materials up to 50mm thick. Independently pivoting blade arms deliver a near-vertical cutting action, helping to achieve cleaner, more precise results.
A generous 406mm throat and tilting table provide ample working space, while the saw is compatible with both pinned and plain-end blades. Blade changes are quick and straightforward thanks to easily accessible clamps. To maintain a clear view of the workpiece, the saw includes an integrated blower, and a 35mm dust port enables connection to a vacuum system for effective dust extraction. The heavy cast iron base adds stability and reduces vibration for improved control.
A truly useful bonus is the power take off with a flexible shaft, for adding fine detail to your work. The supplied accessory kit includes a comprehensive selection of sanding, polishing, cutting, and grinding attachments.
Also included are a blower nozzle, eye guards, and essential service tools. The PD405FS is an ideal machine for those wishing to start a new hobby.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 35 mm
Max Depth of Cut @ 90º 50 mm
Overall L x W x H 630mm x 290mm x 350mm
Rating Occasional Use
Stroke Length 15 mm
Table Size 410mm x 254mm
Table Tilt 0 - 45
Throat Depth 406 mm
Motor Power 125 W
Plug Fitted UK 3 pin plug
Web Attribute Set 230V Scroll Saws
EAN Barcode 5052511142187
