The Perform PD8PTD Power Tool Drill is a practical, affordable choice for beginners or anyone in the market for an entry-level or light-use drill. Offering a balance of convenience, performance, and ease of use, it’s a great fit for home workshops and hobby setups.
Thanks to its compact and lightweight design, this drill is easy to store and quick to set up when you need it. Weighing just 7.2kg, it’s easy to move and store, ideal for compact workspaces. Don’t let the small footprint fool you, powered by a 900W motor and mounted on a 320mm x 310mm base, the Perform Power Tool Drill delivers power and stability without bulk.
A built-in work clamp ensures for secure drilling, while the integrated laser guide shows exactly where your drill bit will make contact. That means no guesswork, just precise, accurate drilling every time.
Fitted with a 1.5–13mm keyed chuck and a self-ejecting chuck key, the Perform Drill grips bits securely. With a generous 70mm of chuck travel it handles a range of drilling depths with ease. Adjusting your speed is simple too, just turn the control knob to shift between 500 and 2,600rpm.
Whether you're drilling into softwood, tubing, or creating pilot holes, this drill is a reliable tool that delivers exactly what you need. Perfect for hobby projects and light DIY jobs.
