The Perform Quick Clamp is a versatile and robust tool built to make clamping even more convenient. Constructed from thick gauge steel, it delivers impressive strength with a maximum clamping force of 1,000 kg, making it well suited for tasks in the workshop or outside. Its tripod leg design provides reliable stability, even on uneven ground-ideal for outdoor or mobile use where a flat surface isn't always available.
Designed for convenience, the Quick Clamp allows hands-free clamping via the foot pedal, particularly useful when securing large or heavy materials. The jaws are reversible and offer a generous 1,050mm clamping capacity, making it suitable for bigger projects such as door installations or to hold large panels. Non-slip urethane jaws help to grip materials securely, reducing the risk of slipping or surface damage during use.
Additional features include integrated footplates that enable you to apply bodyweight for extra stability when handling larger workpieces. Beyond its main clamping function, the Perform Quick Clamp also doubles as a practical workbench. It can support tools or serve as a stable surface for sanding, cutting, or assembly-especially valuable when space is limited or when working outdoors. The weight load is 300 kg.
Despite its solid build, the clamp is easy to store and transport. It folds down compactly and includes wheels for convenient movement and storage under a bench, in a van, or tucked away in a corner. The Perform Quick Clamp is an ideal portable, all-in-one solution for demanding clamping and support tasks.
Overall L x W x H 970 x 950 x 870 mm
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 5052511143276
