Designed to fit the Perform Quick Clamp, these Machine Rails attach securely to the clamp, allowing you to mount a mitre saw and create a portable workstation. Made from durable steel, the rails are built to withstand regular workshop use while keeping your machine securely in place.
The rails aren’t just for mitre saws. Easily attach a drill, sander or even a blank wooden top to create a versatile work surface, giving you the flexibility to adapt your workstation to suit the task at hand.
These machine rails are excellent for those with limited space, or for those wanting a portable solution when it comes to woodworking.
