{"product_id":"perform-quick-clamp","title":"Perform Quick Clamp","description":"\u003cp\u003eThe Perform Quick Clamp is a versatile and robust tool built to make clamping even more convenient. Constructed from thick gauge steel, it delivers impressive strength with a maximum clamping force of 1,000 kg, making it well suited for tasks in the workshop or outside. Its tripod leg design provides reliable stability, even on uneven ground-ideal for outdoor or mobile use where a flat surface isn't always available.\u003c\/p\u003e\u003cp\u003eDesigned for convenience, the Quick Clamp allows hands-free clamping via the foot pedal, particularly useful when securing large or heavy materials. The jaws are reversible and offer a generous 1,050mm clamping capacity, making it suitable for bigger projects such as door installations or to hold large panels. Non-slip urethane jaws help to grip materials securely, reducing the risk of slipping or surface damage during use.\u003c\/p\u003e\u003cp\u003eAdditional features include integrated footplates that enable you to apply bodyweight for extra stability when handling larger workpieces. Beyond its main clamping function, the Perform Quick Clamp also doubles as a practical workbench. It can support tools or serve as a stable surface for sanding, cutting, or assembly-especially valuable when space is limited or when working outdoors. The weight load is 300 kg.\u003c\/p\u003e\u003cp\u003eDespite its solid build, the clamp is easy to store and transport. It folds down compactly and includes wheels for convenient movement and storage under a bench, in a van, or tucked away in a corner. The Perform Quick Clamp is an ideal portable, all-in-one solution for demanding clamping and support tasks.\u003c\/p\u003e","brand":"Perform","offers":[{"title":"Default Title","offer_id":54118779584859,"sku":"113596","price":104.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113596_xl.jpg?v=1789791681","url":"https:\/\/www.axminstertools.com\/products\/perform-quick-clamp","provider":"Axminster Tools","version":"1.0","type":"link"}
