{"product_id":"perform-replaceable-tip-turning-tool-set-3pc","title":"Perform Replaceable Tip Turning Tool Set (3pc)","description":"\u003cp\u003eThe Perform Replaceable Tip Turning Tool Set is a an ideal choice for those who are beginner turners, or those seeking durability and convenience. Each tool measures 330mm in overall length, providing a balanced feel that supports both precision and control during turning tasks. Designed with replaceable tungsten carbide tips (TCT), these tools offer extended life and maintain sharpness longer than traditional high-speed steel alternatives.\u003c\/p\u003e\u003cp\u003eThe set includes three cutter profiles to suit a range of turning applications: an 11mm square cutter for roughing and removing square stock, a 12mm round cutter ideal for curves and contours like the inside of a bowl, and a 10 x 28mm diamond-shaped cutter suited for fine detail work, tight corners and creating beads. The replaceable tip design simplifies maintenance - when the cutting edge dulls, simply rotate or replace the tip and you're good to go again; there is no need to sharpen. Easy to control, these tools sit parallel to the floor on the tool rest. Simply move across the rest to use.\u003c\/p\u003e\u003cp\u003eThe handles are made of smooth beech for a comfortable fit.\u003c\/p\u003e\u003cp\u003eThis set is well-suited for turners who are beginning their woodturning journey and makes an ideal accessory for the Perform PD240WL Woodturning Lathe. They are suited to smaller projects.\u003c\/p\u003e","brand":"Perform","offers":[{"title":"Default Title","offer_id":54118781976923,"sku":"113575","price":54.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113575_xl.jpg?v=1789791855","url":"https:\/\/www.axminstertools.com\/products\/perform-replaceable-tip-turning-tool-set-3pc","provider":"Axminster Tools","version":"1.0","type":"link"}
