Designed for the Perform Replaceable Tip Turning Tool Set, this 11mm TCT square blade is ideal for roughing out material and removing square stock. Simply screw it onto your turning tool. Made from durable tungsten carbide, it stays sharper longer than traditional turning tools, offering extended tool life and consistent performance.
When the edge dulls, simply rotate to a fresh cutting edge. Once all four edges are used, replace the tip - no sharpening required.
Supplied as a 2 pack.
EAN Barcode 5052511143139
